Program freezes
Program freezes
amirTUAF7
Program freezes
amirTUAF7
When i click on "Datei" program freezes so i cant save nor export anything
BimAmbit
I encountered this issue in Revit 2019 and Revit 2020, and I simply resolved it by upgrading Revit. Although I suppose you are experiencing this issue in Revit 2025, upgrading worth a try.
www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Hang-up-in-Revit-when-clic...
handjonathan
Hi @amirTUAF7
Thanks a lot for posting your question to the forums!   Has the solution suggested by @BimAmbit helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
