3D Model not showing up and not showing on sheets.
dragan_nadine
Observer Observer
dragan_nadine
Observer
Observer
I cannot see my 3D model in my sketch of just one particular project. I have restarted my computer, Revit program, and opened other projects to see if the 3D modeling worked there and it did. But one project will not show the 3D model. Also when I hover over the 3D model it "shows highlight" that there is a building structure there but on the pages and in the modeling space it looks blank. I look forward to having the solution! Thanks in advance!
RC_RVT
Try deleting the default 3d view and recreating it, the default 3d view is called "3d View: {3D}". To recreate it once deleted, you highlight the building in a plan or elevation view, then press the Selection Box button under the View section of the Modify tab. Let me know if this works.
leh_dyl
First off, if you double click your mouse wheel (in 3D view), it should zoom to everything in that view. Make sure its not off in the distance somewhere.
Make sure you have no templates on that view either that are hiding every 3D component.
A few screenshots would help you (and us)
dragan_nadine
Observer
Observer
This worked perfectly! Thank you very much!
