I regularly buy planning maps as dwg files from the same online company. I import these into Revit and usually have no issues at all.
However, a dwg I downloaded today will not import and I get a 'serious error' message - see screenshot.
I am able to import other dwg files into the same revit project.
The dwg file will open in autocad (online viewer - I don't have autocad) so does not appear to be corrupt.
Any thoughts...?
Thank you
When encountering issues importing a DWG file into Revit, mainly when other DWG files import without problems, there are a few steps you can take to troubleshoot and resolve the issue:
Check File Size and Complexity:
Large or complex DWG files can sometimes cause issues. Try simplifying the file by removing unnecessary layers or details using a DWG editor or viewer.
Audit the DWG File:
If you can access AutoCAD or a similar tool, run an audit on the DWG file to check for and fix any errors.
Purge Unused Elements:
Use a DWG editor to purge the file's unused elements, layers, and blocks. This can help reduce file size and complexity.
Check for Unsupported Elements:
Ensure the DWG file does not contain unsupported elements or features that Revit might have trouble interpreting, such as certain hatches or custom objects.
Convert to a Different Format:
You can try converting the DWG file to a different format, such as DXF, and then importing it into Revit.
Import into a New Revit Project:
Create a new, blank Revit project and try importing the DWG file there. This can help determine whether the issue is with the specific Revit project or the DWG file.
