Problems with LOAD LAYERS FROM STANDARS
6 REPLIES 6
f_santana
484 Views, 6 Replies
first of all, I would like to apologize for my english. this isn't my mother linguage
I have this layer standard file for DWG, but when I load it to configure my exposure, the category of WALLs and CEILINGs doesn't respond as it should.
I already checked the construction of the file and found no errors.
the error occurs in the treatment of the surface subcategory and in the main
I would like the translation to look like this
but it always modifies to this with each opening of the file
Has anyone had this problem and solved it?
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Fábio Santana
Architect | CAD/BIM Manager
6 REPLIES 6
in reply to: f_santana
.So, you don't want the Color ID? That's all I notice that is different. Am I missing something obvious here?
f_santana
in reply to: barthbradley
Yes, I would like none COLOR ID in this categorys
doing this, REVIT will set the COLOR ID used in the view
@barthbradley  escreveu:
Fábio Santana
That sounds odd to me. What would you expect Revit to do in those "no color" instances?
f_santana
I expect REVIT to accept "empty" COLOR ID in the LOAD LAYERS FROM STANDARS
maybe it will be clearer if you load the TXT file in your DWG export configuration and run it
it worked before, but now it doesn't
p.s. i think my english isn't helping
Fábio Santana
FWIW: It doesn't seem to work in my testing on 2020, 2021, 2022 or 2023.   Revit forces a Color ID in all those versions.
As an alternative, you could create a custom named export setup and transfer it to other projects via Transfer Project Standards.  This method seems to respect the no Color IDs in my testing.
Have a good day.
f_santana
I understood what I had to do to get the configuration I needed.
I realized that the color in view and in section must be the same.
adopting this solved the problem.
I inserted images of the configuration in this publication in the Portuguese language community
https://forums.autodesk.com/t5/revit-navisworks-construction/problema-com-configuracao-de-layers-par...
follow configured file
Fábio Santana
