I have a model that was imported into Revit after an IFC export. Somehow, the lines and points from some of the elements are not selectable anymore, thus it's not possible to give these dimensions in the Assembly Plans.
In the attachments, you will find the corresponding Revit Folder to these two elements. Please check it from Ansichten/Grundrisse/LAGEPLAN. In the "Winkel ABR90", the points and lines of the element are selectable thus dimensionable, on contrary to the "Schubwinkel" above.
Maybe the issue his related to the IFC export or to the opennings in the geometry? No idea.
Please let me know if anybody has an experince with this, or have a solution.
Thank you!
