Problems with duplicating simple structures
MaxJones3
MaxJones3
I have been having this problem off and on since I began this process of creating a fleet of small structures.  When I create a project of a small shed/cabin/studio (foundation, walls, roof, and framing) I intend to duplicate it and set each one to a different roof pitch (shed roof profile).
During my first attempts, I found that having locks and pins on the structure (using floor plan view) caused problems translating everything, especially the framing.  It didn't seem to matter whether I selected-all and then copy-moved or grouped then create-similar.  Once the locks & pins came off, no problems.
After success with this process several times for a variety of structure dimensions, I began to experiment with roof framing of the shed roof profile to see if I could further streamline the reproduction.  After finding that this was inefficient for my purposes, I returned the top plates to level with idea of modifying the roofs individually.
Now, I have the same issues with duplicating this simple structure all over again.  Here are pictures of the problem-instances:
a) Ungrouped - Copy/Move
b) Grouped - Create/Similar
Grouped - Create Similar.png It seems that Revit is made for this sort of precise, parametric reproduction of instances across projects.  So, as weird as this is to me, I must be doing something wrong because this should be routine function.
Any ideas, insight, suggestions as to what is going wrong here?
Thanks again, helpful people!
MaxJones3
This error messages comes up with the Group-Create/Similar problem:
