problems with drawing order
8 REPLIES 8
Message 1 of 9
jlitwill14ZSXCA
508 Views, 8 Replies
I am working on a floor layout and cannot figure out how to move text in front of other details.
8 REPLIES 8
Message 2 of 9
in reply to: jlitwill14ZSXCA
Cut and paste aligned in place the text.
Message 3 of 9
jlitwill14ZSXCA
in reply to: ToanDN
I am very new to Revit and don't know what that means
Message 4 of 9
syman2000
Are you using model text? Model will always hide behind detail/annotation objects. So you may want to use Annotate>text.
Message 5 of 9
I have text both in front and in back and i don't know how to control it.
Message 6 of 9
RDAOU
Select the text and look at the ribbon >>> look for the scissor tool that is cut...after u cut, there is a paste tool with a drop down menu...select paste aligned same place or current view
Message 7 of 9
that didn't work, the furniture is still in front of the text
Message 8 of 9
RDAOU
Try to select the text and on the ribbon choose Pick New Host
You seem to be using model text and not annotations
Under annotation tab there is another form of text...try that one out too
Message 9 of 9
the annotation text worked, thanks for your time
