Problems viewing nested families
nvaazK33TU
nvaazK33TU
We're developing a library of Casework and encountered a display issue when inserting a family into the project. The modules use panels created from nested families, but when inserting them, the display appears incorrect—the panels appear with their original dimensions. Only after the insertion is complete do they adjust correctly. Is there a way to fix this?
TripleM-Dev.net
Shared families, standard behaviour with instance parameters in combination with nested shared families.
During placement the nested families show the default value, and reflect the linked parameter value of the host after placement. Set the default size small or use type parameters (which can't be updated from the host family)
What's the issue, user experiencee during placement?
- Michel
