problem
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
368 Aufrufe, 5 Antworten
problem
problem in revit 2017  cannot load family files as example ;door
5 ANTWORTEN 5
Nachricht 2 von 6
rudi.roux
als Antwort auf: Anonymous
Hi @Anonymous
Welcome to the community! Smiley (fröhlich)
Did you load the default Revit Content when you installed Revit?
The default installation locations for the Libraries can be found under:
Revit 2016: C:\ProgramData\Autodesk\RVT 2016\Libraries
Revit 2017: C:\ProgramData\Autodesk\RVT 2017\Libraries
It might be that someone moved your default Library Location.
To see if it installed, go to Uninstall a Program to see if it actually installed:
OR
Are you trying to load an - e.g. Door Family Type which was possibly upgraded to a later Revit Version and now you are prompted with an error message?
I hope this helps! Smiley (zwinkernd)
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Nachricht 3 von 6
als Antwort auf: rudi.roux
I
Download with the installation but some working and doors and windows not working
Nachricht 4 von 6
Did you use Insert Component instead of Doors when you initiated the
command? If you need to insert a Door then use the Door button in the
ribbon. Revit is very specific and only allows the family of the same
category from the command to load.
Nachricht 5 von 6
@Anonymous
See the screencast below for further clarifications.
  1. Use Component tool to insert a Door: failed
  2. Use Door tool to insert a door: okay
  3. Use Insert > Load Family tool then you can load any kind of family.  Find it in project Browser/ Families and place it in view.
Tags (1)
Nachricht 6 von 6
als Antwort auf: ToanDN
