problem
problem
problem
problem in revit 2017  cannot load family files as example ;door
rudi.roux
Hi @Anonymous
Welcome to the community! Smiley Happy
Did you load the default Revit Content when you installed Revit?
The default installation locations for the Libraries can be found under:
Revit 2016: C:\ProgramData\Autodesk\RVT 2016\Libraries
Revit 2017: C:\ProgramData\Autodesk\RVT 2017\Libraries
It might be that someone moved your default Library Location.
To see if it installed, go to Uninstall a Program to see if it actually installed:
OR
Are you trying to load an - e.g. Door Family Type which was possibly upgraded to a later Revit Version and now you are prompted with an error message?
I hope this helps! Smiley Wink
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
I
Download with the installation but some working and doors and windows not working
Did you use Insert Component instead of Doors when you initiated the
command? If you need to insert a Door then use the Door button in the
ribbon. Revit is very specific and only allows the family of the same
category from the command to load.
@Anonymous
See the screencast below for further clarifications.
  1. Use Component tool to insert a Door: failed
  2. Use Door tool to insert a door: okay
  3. Use Insert > Load Family tool then you can load any kind of family.  Find it in project Browser/ Families and place it in view.
