How to change the default length of the leader line of a tag?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
7043 Aufrufe, 4 Antworten
The leader line is too long and i don't want to change it manually each time i place it.
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: Anonymous
Activate a tag function. Than before placing the tag set the proper length.
This (default) length will be kept during the session or until you change it to a different value
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
rudi.roux
Hi @Anonymous
Hope you are well. Smiley (fröhlich)
Further to what @L.Maas suggested, which is exactly where you change it, I would like to add the following which gets overlooked.
If you have 100x Windows already tagged with say 10mm leaders and want everything to be 5mm leaders. Then you select all instances in the view, delete it, then go to Annotate >> Tag >> TAG ALL, then follow the image below:
I hope this helps! Smiley (fröhlich)
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Nachricht 4 von 5
gtarch
als Antwort auf: rudi.roux
That is the answer Rudi!
For years I wanted to change the default leader length.  And there it is, buried in the TAG ALL command.
Many thanks.
Nachricht 5 von 5
dal
Hi
As a follow-up on this question - is there any way to change the std. 12.7 mm? I know as described, that you can change it before tagging - But you have to do that every time you use the tag-command.. Is it possible to make a custom leader-lenght as std.?
