Problem with Wall Edit Profile / Reset Profile when dimension is associated
- Mute
- Permalink
- Report
I have a problem with my Revit 2020 after update ~10/6/19. Same files on a different PC ...no problem and behave correctly.
On any file I open I cannot edit or reset "wall" profile of any wall opening that has a dimension associated with it; if no dimension or I delete all dimensions in every view associated with opening then I can delete in edit mode or reset profile. I can move a line to change dimension but cannot delete any part of opening. If I try to delete an opening and select "finish check mark" it will not respond, instead my only option is to use the "X" and exit without saving. Normally an error message would pop up and say that a "dimension reference is invalid", but this is not happening!
Any help ???
