Problem with view camera creating white squares
laygy1
Observer Observer
laygy1
Observer
Observer
hi im just fustrated and cant seem to find the solution to this anywhere. All i do is select the camera then setup a view in the site in my case a room and try to show everything however there is a massive white square blocking the view. thanks for your help (image is attached)
Alan.johnson1970
When placing the camera in the plan view did you drag past the wall or stop short before the wall?
When placing the camera, You need to drag past the objects that you want to see.
AJ.
cbcarch
Uncheck "Far Clip Active" in View Properties.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
noraN3KU8
Community Visitor
Community Visitor
Very helpful!
