Window tag with spot elevation
6 ANTWORTEN 6
Nachricht 1 von 7
eyalbRAPVR
1738 Aufrufe, 6 Antworten
I am trying to create a window and door tag that shows the sill height relative to the project base point. In other words to create a tag that includes a spot elevation. Anyone has any ideas how to do it?
Tags (2)
6 ANTWORTEN 6
Nachricht 2 von 7
cbcarch
als Antwort auf: eyalbRAPVR
You could investigate something like this:
https://www.youtube.com/watch?v=EaqvaA7FYV4
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 7
I'm just curious to know what your Project Base Point is relative to?
Nachricht 4 von 7
eyalbRAPVR
als Antwort auf: cbcarch
my request was misunderstood. I am trying to create tags that withdraw the sill height relative to the project base point and not the level. I know may apps that can do that but I do not want an app for that, I want to see if someone knows how to connect spot elevations to tags.
Nachricht 5 von 7
eyalbRAPVR
als Antwort auf: barthbradley
to one of the site's measured corners. That is what we do always.
Nachricht 6 von 7
Which Apps are you referring to? I'd like to check them out.
Nachricht 7 von 7
Simply change the host level of the windows to your datum level and add Sill Height to the Tag label.
