PROBLEM WITH REVIT 2017 (COLOR SCHEME)
HELLO FRIEND FORUM, WHICH HAVE A PROBLEM hope you can help me, I'M TRYING THE REVIT 2017 AND WHEN I WANT
USING A PLANT WITH COLOR SCHEME, THE COLOR preempts ALL THE SECURITIES TO STAND IN REVIT 2014, ME THAT APPEARS NO PROBLEM, I WILL ATTACH A PICTURE, HE TRIED AND I DO NOT GIVE SEESQUEMACOLERES.jpgVERAL CONFIGURATIONS WITH THE SOLUTION Helpme PLEASE!
Change the Color Scheme Location to Background.
ToanDN gracias por responder, esa no era la solución, el problema era que tenía que desactivar la opción de aceleración de hardware, gracias de todos modos.
Glad you fixed it.
thanks for answering, that was not the solution, the problem was I had to disable the hardware acceleration, thanks anyway.
