Structural deck for roof
Consultant Consultant
Message 1 of 8
Is there any reason that Structural deck layer is available for Structural Floor but not Roof?  How would one add a fluted deck without model a structural floor under the roof and deal with all the coordination problems, or model the entire roof a floor and miss all the roof-only features?
Replies (7)
Message 2 of 8
chrisplyler
I suppose I would either:
1. Model a structural floor and then a roof right above it to account for other layers, or...
2. Model just a roof, and then in a section view use a detail region shaped like your deck pan to cut the right shape into the concrete layer.
Message 3 of 8
I have been avoiding cutting the details across the flutes wherever I can. When it is a must I am doing number 2 and feeling like crap.
Message 4 of 8
chrisplyler
I feel your pain. Any chance you could do it as a structural slab, and then just modify a floor/slab schedule to filter the others out and rename it to read as a roof schedule?
Message 5 of 8
That is one workaround I have also considered. Scheduling and classification are not really a problem. What nice about roofs is they can be generated based on some goofy looking mass surfaces. Structural floors can't.
Message 6 of 8
Can the annotate "Detail Component" of the Deck section profiles be turned into a "repeating detail component"? If so, do you have a link on how to do so? That seems like a more usable tool than simply placing a single flute of decking at a time when detailing......
Message 7 of 8
never mind........ lol that was easy enough.....
Message 8 of 8
martijn_pater
I think the reason that it's not possible to use a structural deck profile for roofs, is because of the way roofs are generated ie. it has pitches in multiple directions or you can create roof by face/extrusion so then it's not nescessarily a section which would allow for the use of that. But since a structural deck is usually for flat roofs probably, you could just use a floor.
