Problem with Region command Revit
6 REPLIES 6
enafisifar
366 Views, 6 Replies
I have an issue with Revit 2023 and i can't resolve it. Actually when I create a filled region , Revit dosen't show anymore my plan view as you can see in the photo below.
I wonder if there is an option that i can use to resolve my problem.
Thank you
6 REPLIES 6
in reply to: enafisifar
Is Detail Items Category turned on?
enafisifar
in reply to: barthbradley
I've alrealdy controlled it and it's on!
kostask_oionei
Check in Tab Manage - Additional Settings - Line Styles the color of <Thin Lines>. Maybe by mistake it is set to white.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Turn On Lines category and all subcategories inside it.
enafisifar
in reply to: ToanDN
Lines category and all subcategories is on! becuase I can see all the lines category in plan view when region command is off!! for example you can see my screen shot below and you can see a normal plan view!
enafisifar
in reply to: kostask_oionei
I've checked them and they're set as normal setting.
