Problem with Realistic View in Revit 2022
Message 1 of 29
Realistic View is not showing anything (can't see surfaces, lines, etc)... when hovering over an element, the blue 'select' outline appears, but otherwise the 3d view looks empty. Shaded view and hidden line views work normally. I have tried deleting the general 3d view and regenerating it, but nothing changes. My PC has an AMD Radeon 6900 xt GPU and an AMD Ryzen 7 3700x CPU. Would greatly appreciate some help! Has anyone else encountered this issue?
Nate
Replies (28)
Message 2 of 29
syman2000
Try updating graphics card. Check this website and see if it will help
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 3 of 29
Thanks for the suggestion. I tried updating the graphics card driver and I also went through the post you sent. Unfortunately, nothing worked.
Message 4 of 29
cbcarch
Check here: https://forums.autodesk.com/t5/revit-architecture-forum/model-is-not-visible-in-realistic-view/td-p/...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 29
Lance.Coffey
Autodesk Support
Autodesk Support
If the info in the links above are not leading to a solution, check if the following article applies (i.e. issue only occurs when double clicking to open models): Realistic Views do not display geometry and there is a prompt to submit an Error Report on exit in R...
Lance Coffey
Technical Support Specialist
Message 6 of 29
Thanks - I can now see the model, but there is still something going on with the surfaces. Please see the attached screenshot. It looks as if there were two elements on top of each other, but there is not.... The surfaces also 'flicker' and the grey/white areas (which aren't supposed to be there) move when I orbit.
Message 7 of 29
Lance.Coffey
Autodesk Support
Autodesk Support
@Anonymous From your screenshot, it looks like Z-Fighting is occurring.
If you aren't finding two overlapping elements, try deleting the one you can select, and see if another remains visible (maybe one of the elements is not selectable). If everything disappears when you do this, then undo the delete.
Lance Coffey
Message 8 of 29
Lance,
It appears like there are overlapping elements (Z-Fighting), but there are not. For some reason, it looks like this is happening across the model and only in realistic view... even when I create a new object/element by itself - off to the side.
Message 9 of 29
la1806645
Hi, I had the same problem, what worked for me is to make the emissivity of all the lights equal to ZERO, and to open the project from Revit homepage rather than double clicking the project itself, that is to open Revit then open your project from there.
Hope it works!
Message 10 of 29
GustavoUbriaco
Thank you @Lance.Coffey I had the same problem and noticed when I opened the project inside revit the realistic view works, hope there will be a hotfix soon.
Best regards, Gustavo
Gustavo Ubriaco Contreras
Message 11 of 29
konetarchitecture
I am experiencing similar, if not identical issues with REVIT 2022.  It doesn't happen all the time, just randomly.  As suggested by Autodesk, I do open all my projects through the Revit desktop app and on occassion my elevations will become a dark grey color (not what they are programmed to be) and there is often a secondary outline of portions of the elevation(s).
I've set all of the views to PHASE: NONE and I still have this issue.  What am I supposed to do to remedy this?  Is Autodesk working on a fix?
I have a 2019 BOXX APEX S3.04 with 32 GB of RAM, but there is often a warning stating I need more memory???
Message 12 of 29
Manaf.Abdulghani
Observer
Observer
Same problem though I am running Revit 2022 on a Mac, have you tried camera view? it worked for me
Message 13 of 29
 I am experiencing the same problem: The 3D Realistic view was coming up completely blank, but the view worked in Hidden Line mode.  I tried the fix mentioned above, i.e. opened Revit software then opened the model.  It worked.  The 3d realistic mode is now working normally.  What a weird bug!
Message 14 of 29
Lance.Coffey
Autodesk Support
Autodesk Support
The 2022.0.1 hotfix has been released and includes an update that should clear this behavior.
Lance Coffey
Message 15 of 29
hi @Lance.Coffey I just recently installed the revit 2022, with the suggestion here i also installed the 2022.0.1 hotfix...surprisingly, it didn't solve my own realistic view problem...please is there a way I can fix this? because mine has no walkaround, it occurs irrespective of how the file was opened, be it through the software or file explorer.realistic view in wireframe and part blankrealistic view in wireframe and part blankshaded view working wellshaded view working wellhotfix showing installedhotfix showing installed
Message 16 of 29
Neon6
Observer
Observer
I've been struggling with this for days as I do an evaluation of Revit 2022. Sadly, when I asked support for how to obtain the hotfix, they said the hotfix is not available to people on trial. So of my thirty days of trial, 30% of my time has been spent working around crashes and bugs like this. Can anyone confirm if the hotfix is available to trial users. The point is kinda moot as my trial is almost up. 😪
Message 17 of 29
I have a classroom with 30 computers. It works on some but not on others, really wierd.
Message 18 of 29
Neon6
Observer
Observer
Just curious if this occurs consistently on the same computers in your classroom (or is it more random in time).  I was thinking this was probably a timing bug (also known as a deadlock in software speak). But if you see it consistently on some computers and not others, then I'm wrong and it's something else.
Message 19 of 29
2IAMGIANG
Observer
Observer
I got a similar error. Have you found a solution ?
Message 20 of 29
I have not seen a solution. I always have to make sure I load projects from
the Revit home page rather than double clicking on the file name. Otherwise
realistic view doesn't work.
