Model is not visible in Realistic view
Message 1 of 11
My model is not visible when I switch to Realistic mode.  When I fence select I can see it (see attached screen shot) so I know it's there.
Works fine in Wire Frame, Hidden, Shaded and Consistent Colors.
Replies (10)
Message 2 of 11
metsuyanim
i have the same problem
Message 3 of 11
chadwickt
Can you post the Revit file?
Message 4 of 11
2022?. Might be a BUG. Same thing happened to me. I was finally able to resolve by closing and restarting.
If not 2022, then maybe it's just a corrupted 3D View, which does happen from time to time.
Elements appear wireframe in 3D view in every visual style in Revit | Revit Products | Autodesk Know...
Message 5 of 11
Yes 2022.  I've closed an opened a few times and it did not help.  I didn't mention in the original post but this is happening in all views (3D, Plan, Elevation and Section)
Message 6 of 11
Yeah, I went through the same thing.  I meant I actually restarted my computer.  Frankly, I don't think it's "fixed" though.  Maybe for this one time it is, but I'm thinking it'll happen again.  Whatever. New versions always reveal BUGS initially.  I'm betting there's a hotfix dot 1 that will fix numerous issues in less than a month - same as past new releases.
Message 7 of 11
sureshchotrani
Kindly share the Journal file to troubleshoot the issue.
Does this occur with sample file as well?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 8 of 11
Sample file works fine.  See attached journal file.
Message 9 of 11
sureshchotrani
While reviewing Journal I see, graphics card used is nvidia geforce gtx 1050, which is quite old released in 2016 and isn't certified even for Revit 2021 version.
Further I see below warning -
DBG_INFO: OGS Error Type OGS WARNING: , Description - Unable to connect to the ArchVision Dashboard at the following address:
'127.0.0.1:14931
And further I see below lines in Journal -
'You may need to check with your office administrator
'to obtain the correct information.
Kindly disable any elevated security and Antivirus and open Revit 2022 via Right click Run as administrator and see if that helps.
Further can also look for solution mentioned in article -
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 10 of 11
shahzadahmad7412
Community Visitor
Community Visitor
am also face this same problem can u help me?
Message 11 of 11
2023-1-01535
Community Visitor
Community Visitor
happened to me today. checked the older version of my file and realistic view shows perfectly. realized it was one of the downloaded family creating this error. deleted it and purged my unused families and it works fine again now.
