When i try use "room" function to place room, i cant place it to only 1 room, it places to all whole floor. And boundaries higlighting says, that he "see" the wall boundaries. I tried to place room to different offset and upper limits, but thats didnt work. Any problem solution?
Solved by imankassab2015. Go to Solution.
Upload the file but
Check walls in the properties panel choose room bounding to be checked on that's the prb for all walls
Accept my answer if it helps you
Hi, I uploaded my project to my first post. Checked all the walls and all walls has room bounding option to "yes". If you have any ideas, I will be grateful hear that.
I got your prb it will be tedious work I checked your plan is full of overlapped walls and columns causing the room not working well the work around is to clean up and use room sperator line
Maybe you can send examples of overlapped walls and columns? Bcs i didnt found it.
Check door tag 45 first floor lemenis in the pic below
Thanks for help, but i cant see anything overlapping in my project. I just tried to use allign fuction to be 100% sure to my walls are connected to columns and have same problem with rooms. If you can, please send photo with actual overlapping problem.
