Problem with "color fill legend"
Message 1 of 12
I'm trying to use "tag room" comand and have two question:
1) for the command "room" I can't use "copy to clipboard " and then riproduce the room in an other plan if the two level are ugual? The software cannot do it when I've trying to do so.
2) I use the same command "copy to clipboard" for tag room and then "paste to aligned view". I can use the command but in the other level (level 1) I don't see at all ant tag paste from the level 0.
3) In the color fill legend there is a room in color green (the sixth room on the legend) that doesn't exist.
How can I fix the problem?
.rvt attahed.
Thanks'
Replies (11)
Message 2 of 12
MostafaElashmawy
regarding number 1 & 2, you should copy paste the room and its tag. you can copy both in same step.
check below video.
https://knowledge.autodesk.com/community/screencast/1093d080-459f-47a1-9310-b88640c4fa1e
1093d080-459f-47a1-9310-b88640c4fa1e,640,650
Mostafa Elashmawy
Message 3 of 12
MostafaElashmawy
for point no. 3, You need to select the legend, edit type, select to show values by view.
Mostafa Elashmawy
Message 4 of 12
@MostafaElashmawy  thank's for your answer.
For the command room 1.jpg1.jpg if click on level 0 and then copy and paste as 1.jpg1.jpg it goes to all the room.
But for the tag room you use "aligned to a current view". But if I have a building of more than 1 level from earth have to open every view with   "aligned to a current view"?
There isn't possibility to select all the level with one command as with "aligned to selected level"? As from the comman "room" in this case but as from wall or windows in and other generic project?
Thank's
Message 5 of 12
MostafaElashmawy
Sure you can paste aligned to selected level.
But to copy the tag, you should have rooms first so:
1- select room with its tag.
2- copy to clipboard
3-paste aligned to selected level.
Mostafa Elashmawy
Message 6 of 12
Are unselecteble with "aligned with selected level".
If i click on "Aligned on select view" say me "tags are not copy because I can't find an host."
Message 7 of 12
MostafaElashmawy
What about:
1- select room.
2- copy clipboard
3- paste aligned to selected levels.
then
1- select tag.
2- copy clipboard
Mostafa Elashmawy
Message 8 of 12
1- select room.
2- copy clipboard
3- paste aligned to selected levels. ==> ok, works.
then
1- select tag.
2- copy clipboard
3- paste aligned to selected levels. ==> are unclickable.
Message 9 of 12
MostafaElashmawy
sorry I was not concentrating enough.
The tags are 2D elements. so can't be copied through levels.
But you can copy tags through views.
1- select tag.
2- copy clipboard
3- paste aligned to selected Views
Mostafa Elashmawy
Message 10 of 12
@MostafaElashmawy  can you try please?
If click oin "current view" and than open the view of my concern (level 1 in my case) works.
"Select view" are clickable but when select the level of my concern a view nothing.
I'm speaking about the TAG ROOM
Message 11 of 12
MostafaElashmawy
check below video
https://knowledge.autodesk.com/community/screencast/78aaef79-b383-4c78-b960-77c33f39d2a4
Mostafa Elashmawy
Message 12 of 12
@MostafaElashmawy  sorry, i'm wrong to select level:
I just kept hitting on "area plan affittable" and not on "floor plan" selecting the view to copy.
Sorry, thank's very much!
