Problem with PLT Plotting
2 REPLIES 2
amirLT2JD
252 Views, 2 Replies
I'm having a problem with PLT exporting.
Every time that I export PLT file from REVIT and all the text is one big mess (I'm writing in Hebrew( .
The text is in a diagonal position and the line is overlapping each other.
I tried to change the font, its change the position but still unreadable.
The PDF\DWF plotting is fine, but I need the PLT too.
Does anybody encountered a similar problem and manage to fix it?
Tags (3)
Labels (3)
2 REPLIES 2
a_meteni
in reply to: amirLT2JD
Just wandering why you still need the .PLT file format while the PDF/DWF files are there?
Do you have a .PLT viewer or the attached snapshot is from the plotted sheet?
amirLT2JD
The PLT is required by the project manager.
I'm not sure that I fully understood the second question: I plotted the sheet to a file in PLT format, and I open the PLT with "ViewCompanion" and take the attached screenshot.
Forma Design Contest
