02:00 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a Revit family (made in Revit 2016) with a lookup table attached. When I export the lookup table in Revit 2018 and then import that same csv file without editing it it gives me this error :
Invalid formula found in the "%1!s!" parameter in the "BMG_default" type.
You will need to import the correct table or edit the formula in order to continue.
The lookup table has not been changed or edited after the export. Because of this problem I can't change the lookup table without redoing all the old settings etc.
I can not post the family because it is a confidential family. Hoping someone solved this problem already.
