Problem with expansion joint family
Message 1 of 9
I'm trying to create an expansion joint family as decribed in a previous post:
How to model floor expansion joints?
https://forums.autodesk.com/t5/revit-structure-forum/how-to-model-floor-expansion-joints/td-p/532868...
I have two problems:
1- The void lenght of the nested (generic face based) family is not the same when I associate the length parameter of void length to length parameter in line based family.
2- I can't cut the floor and the family with the cut tool when the familly is loaded.
I don't undestand well everything seems right.
The rfa is in this link.
https://we.tl/FcB8ANEFlO
Thank you in advance.
Replies (8)
Message 2 of 9
dzanta
Please resend the revit family you built so I can look at it.  Thanks
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 9
https://forums.autodesk.com/t5/revit-structure-forum/how-to-model-floor-expansion-joints/td-p/5328681
I resend the link
https://we.tl/VubLNRTgcm
Message 4 of 9
dzanta
i will let you know asap today
Message 5 of 9
dzanta
Here you go....fixed.
The void family needs to allow for cutting of host.
Message 6 of 9
Ah!
Ok thank you very much @dzanta
I have already the problem described in the first point.
Message 7 of 9
Edit the nested void family, drag the grip of the void extrusion the snap onto the reference plane and lock it.  The reload it to the line based family.
Message 8 of 9
Thank you very much.
I changed my sweep by an extrusion and locked.
That works perfectly.
Message 9 of 9
I am not an expert in engineering or installations, but recently I had some problems with the expansion joint, and I consulted with some experts. For my situation, they also sketched a project in Autodesk and Edited the nested void family, dragged the grip of the void extrusion the snaped onto the reference plane, and locked it. Thanks to those sketches and diagrams, they managed to execute the expansion joint repair much more effortlessly. Indeed, some experts do much better in such cases than we do.
