Problem with Devide Surface
v-tahmasebi
v-tahmasebi
I'm trying to grid this ramp using the Divide Surface component.
However, as you can see in the pictures, the result turns out wrong or distorted.
I also tried using the Empty and Overhanging options, but they didn’t help.
Is Divide Surface even the right approach for this kind of geometry?
What would be the proper solution?
v-tahmasebi
Any one couldn't help me!?😥
pavankumar.h
Hello @v-tahmasebi
Thanks for reaching out us on Forum.
A similar issue has been captured in the below article which helps to address the issue.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Pattern-of-the-div...
I would request you to follow the steps mentioned in the article and do share your observations.
Thanks!
