Problem with cropped view
3 REPLIES 3
ianburtney
253 Views, 3 Replies
My cropped region is misaligned with my model view and I can’t find the model (the crop region has become very large). Is there any way to align the region back to the extends of the model?
3 REPLIES 3
kadmonkee
in reply to: ianburtney
in that view uncheck crop view and check crop region visible, with a crossing window select everything in your view to locate your model, then select the crop region and adjust it accordingly.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
syman2000
Usually what I do is edit the crop region. Delete the pink lines. Zoom in and then draw your new pink lines. As well turn off CAD link if it is in your 3d views.
ianburtney
in reply to: syman2000
Brilliant, thank you! That worked a treat.
