Problem with 3d visualization
Hello everyone, I have a problem with the visualization in the 3D view, some time ago I began to work on a project that was originally created in revit 2015 in the 2017 version, but when I started to modify some details lines began to appear in all the modeling , this only happened inside the 3d view, but it is something that currently makes it difficult for me to work.
I wanted to know if someone can give me a solution to this problem, previously and asked in another forum but in Spanish and I have not received any response.
Postscript: sorry English, I wrote it with the help of a translator.
Hola a todos, tengo un problema con la visualización en la vista 3D, hace algún tiempo empece a trabajar un proyecto que originalmente fue creado en revit 2015 en la versión 2017, pero cuando empece a modificar algunos detalles empezaron a aparecer lineas en todo el modelado, esto solo paso dentro la vista 3d, pero es algo que actualmente me dificulta para trabajar.
Queria saber si alguien me puede dar una solucion a este problema, anteriormente e preguntado en otro foro pero en español y no e recibido ninguna respuesta.
Posdata: disculpen el ingles, lo escribi con la ayuda de un traductor.
Turn off any CAD links or imports for that view.
Thank you very much ToanDN for answering me, the solution to my problem was solved by creating another 3d view by default.
