problem while saving
Andre.GG
Message 1 of 14
Andre.GG
Hello guys, from the past 2 days my Revit 2020 start to don't save files anymore, from a new file and from an old one the answer is always the same, "failed to open document" and after this, he said "Impossible to save" and this happens for new file and old ones.
Can someone have some advice?
I already uninstall and installed Revit again( 2 times).
All the file are from the same version.
One strange thing that happens is that when I copy the elements of a project in a new file and I try to save it I do it, but if I try to export a render o a plan in DWG he doesn't do it.
Replies (13)
Message 2 of 14
Does it say "Viewer Mode" at the top of your screen?  Doesn't sound like your running a licensed version of Revit.
Message 3 of 14
Andre.GG
I have the regular student version, I use Revit 2020 from the past 5 months.
Between the Revit version and the file name I have (STUDENT VERSION Written)
Message 4 of 14
joe_keogh
Hi @Andre.GG
Can you check the Available space on your C: Drive, go to Windows Folder Explorer, and This PC,
under the C: Drive is the Available space greater than 20Gb?  If not this may be the issue.
If you are working of a network drive, please confirm you have Read Write access to the folder you are saving to.  you will probably need to check with your IT Manager.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 5 of 14
Andre.GG
Thanks for the advice I check, the hard drive and I have 208GB, and no I don't work in the network only in local, I always saved in the desktop and yesterday I did a test, I try to run Revit like administrator and nothing change, but I have saved a new file in the local disk directly, I try with a file that I already did and this makes crush Revit.
So I don't have any idea of what is happening.
Message 6 of 14
Andre.GG
please, guys, someone can help?
I can not use Revit anymore if I don't fix this
Message 7 of 14
RobDraw
This is not normal behavior. Either reinstall the program or contact Autodesk support.
Rob
Message 8 of 14
Andre.GG
My problem is that I have already uninstalled and installed it 2 times.
I try to use my projects in another computer and they work normally so I really don't understand what is going on.
Message 9 of 14
RobDraw
Did you do a full uninstall using instructions provided by Autodesk before reinstalling?
Rob
Message 10 of 14
Open up a Support Case through your Autodesk Account.
https://knowledge.autodesk.com/contact-support/using-my-product
Message 11 of 14
Viveka_CD
Message 12 of 14
Andre.GG
ok i will try to do this.
thanks
Message 13 of 14
Andre.GG
i did it alredy, 3 weeks ago.
Message 14 of 14
Andre.GG
