Problem when using lines with thickness
1 REPLY 1
153 Views, 1 Reply
I need a dashed line with thickness to indicate fire classification, the problem is that every dash gets rounded end caps. I want every dash to have straight end caps. Does anyone have a solution to this problem?
Regards
Helge Mjos
1 REPLY 1
Yes. And a very good one. Use the repeating detail feature. With this you can make lines of just about any type that you can imagine. "Pelge" wrote in message news:31006157.1083153613041.JavaMail.jive@jiveforum1.autodesk.com... > I need a dashed line with thickness to indicate fire classification, the problem is that every dash gets rounded end caps. I want every dash to have straight end caps. Does anyone have a solution to this problem? > > Regards > Helge Mjos
Forma Design Contest
Technology Administrators
