Problem When Load Family Inside model in place
Message 1 of 8
When Load Family Inside model in place  the Generic Annotation of the loaded family disappear. What is the reason?
I upload the family and a screencast.
Thank you.
Replies (7)
Message 2 of 8
L.Maas
I do not know the reason, maybe not considered, or maybe by design or maybe a bug.
However, why are you place a loadable family inside an in-place component? Normally in place components are used for special (one-off) models. And as soon as you will have multiple instances of a component you will usually create a loadable family. I seldom use in-place components.
However if you want to use a generic annotation inside the in-place component you could load it directly (not hosted in your loadable family), then it will show.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
Thank you. using the generic annotation directli inside the in place family doesn't solve my problem.Because I will use more than one family inside the model in place and each one will have different parameters.
Message 4 of 8
My guess is that the Generic Annotation's "Show only if instance is cut" is CHECKED.
How'd I do?
...just tested.  Here's how the component looks on placement into in-place editing environment:
...and here's how the component looks after clicking on Finish Model and exiting In-Place Editor:
Message 5 of 8
L.Maas
But still the question. Why do you place loadable families inside an in-place component?
We normally try to avoid in-place components. Only for one-offs and if we do not need them in future projects.
So placing loadable families inside an in-place family seems odd to me.
On top of that, why model as loadable family and not use the walls system family?
Louis
Message 6 of 8
I would agree with you, @L.Maas.  Still, the disappearing Anno trick was neat.  I don't know if I'll ever have a practical application for it though.  Smiley Wink
Message 7 of 8
L.Maas
@barthbradley I have looked and this is not the case. It is unchecked in the family
@Anonymous I tried some other settings and I noticed that when I set the family "Partition-Wall-System-001-1.rfa" to shared the generic annotation will be shown when clicking finished....weird.
Louis
Message 8 of 8
I hadn't notice that the OP posted the file. Just downloaded and tested your solution and it works like a charm! Now the question is WHY it doesn't work when it's not shared.  Hmm?  I got to think about this.
Thanks for sharing, @L.Maas.
