Hi everyone,
I am having a problem displaying doors and windows in the Ceiling Plan. In the floor plan, the frames appear cut, showing the panels and even the glass. However, in the Ceiling Plan, the doors and windows appear as if they are in view.
I have tried several tests with cutting planes in the View Range, but the result is the same. I have also tested with various door and window models, both native to Revit and downloaded from the internet.
Has anyone else had this problem? How can I fix it?
Thank you
Solved by barthbradley. Go to Solution.
It all depends on what you want or need to see in the ceiling plan. Do you want to see them or not? Then simply adjust the height of the cutting plane.
That was it, the View Range was different in the Ceiling Plan compared to the Floor Plan in the Window properties
