Problem to create local file in Revit
Message 1 of 9
"Revit could not create a local file from: ........
This could be due to a network problem"  (is not)
Replies (8)
Message 2 of 9
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! I see that you are a new visitor Smiley Happy
Did you have a specific question? I'm trying to understand your issue.
Which version of Revit are you working on?
Did you get an error? Can you please post a screenshot?
Glad to help and I look forward to your reply!
Message 3 of 9
Corsten.Au
1. Make sure you are opening a Central File
( it should give few options like. a ( Detach from Central ), b ( Create local )
2. Make sure the local file path is set... default is usually in ( Documents ) folder.
3. If you can open the file detaching it then network is not the issue.. but if you cannot open it
then its probably Network issue...
4. Most important is to create a local file ONLY using CENTRAL file..
Best luck
Corsten
Building Designer
Message 4 of 9
HEETESHC
I am facing an issue with my Revit software 2018, 2017, 2016 & 2015 as well and to overcome this I tried to re-install the whole software package.
the problem is that all the Revit users in the office are able to open their central files simply by using the option "create new local" command that appears on the screen however on my machine this option doesn't allow you to opt that option(fades out / we can say unfocused). image attached for more clarification.
Message 5 of 9
Viveka_CD
Hi @HEETESHC
Can you verify the steps recommended by @Corsten.Au, if it does not solve your work, please make a new post and ping me by adding @Viveka_CD
Message 6 of 9
HEETESHC
Hi @Viveka_CD, Thanks for Support.
Now I fixed the issue.
The issue is about mapping Drive was incorrect.
Once again thanks.
Message 7 of 9
Viveka_CD
@HEETESHC awesome, that's good to know!
Thanks for getting back to us!
Message 8 of 9
sami.ieaconseils
HIIIIIIIiii   How the problem became
Message 9 of 9
juan.osorio8P7US
Observer
Observer
Can't create a local file from central. Before opening the checkbox that say "create a new local," is grey out and isn't letting me check on or off. But all my coworkers using the file isn't having any issues with it.
