problem creating a slopped / triangular curtain wall
hi
i'm trying to create a slopped curtain wall but i face a problem doing so.
first i've created a conceptual mass, then i've created generic wall depending on the faces.
the faces is traingular and slopped at the same time.
when i try to turn the generic wall into a cutain wall i get the following error.
any suggestions?
Melina.Vlachousi
For a mass face you would use a curtain system:
This tool can also be found in the Massing & Site tab.
the point is that the walls is updated so that i can't rely anymore one the original mass?
is there is a way to do it with the current walls?
Normally that error message suggested that the face I picked was not planar, hence a curtain wall could not use it. But I can't confirm with only looking at the screenshot. Try a curtain system as mentioned by @Anonymous.Vlachousi. It should work for non-planar faces.
