The colour scheme doesn't print to PDF, when there's a ceiling on top of it.
When I delete the ceiling (go to 3D view, click on it and delete it), and PDF print it again, it shows properly.
Is there a way to print it without having to manually delete the ceiling?
Gelöst! Gehe zur Lösung
Gelöst von FGPerraudin. Gehe zur Lösung
If you turn off the ceiling in the Color Scheme view or set it to transparent, it is still blocking the color when you print?
@Anonymous hello, you can right pick the ceiling and choose hide in view (elements or category) 2nd options go to visibilty graphics and unhide ceiling. then you print without the ceiling. thanks
@Anonymous hello, I know what is your concern. You only hide the ceiling per view other views will not be affected. Have you tried? Why don't you try first if doesn't work, then follow up with other comments. We cannot narrow the problem if you did not follow the suggestions. Thanks
Hi Carla.
First question, is it a ceiling plan view or a normal plan view?
If the ceiling appears in a normal plan view, tne you need to check the view range in the view properties for the ceiling not t appear...
If it is a ceiling view, the colors scheme should appear as normal. The trick is to make them transparent in the visibility / graphics properties of your view.
Hope this was of help,
François
Francois-Gabriel Perraudin
BIM management and coaching
In the project browser, double check that you are using a view that is under "Floor Plans", not "Ceiling Plans". Seems to me that you are in one of the ceiling plan views, not in floor plan view.
@Alfredo_Medina Yup, I just realized that it could be, he/she is not in the correct plan view. thanks
