Problem Completing - Part 1: Create a Project and Add Levels Tutorial
I'm unable to locate the Place Level tab > Draw panel > Pick Lines as instructed in Add Levels - step 5 in the Autodesk Revit 2020 Getting Started tutorial.
Any advice?
Thanks, Jacqui
ennujozlagam
you can refer to this LINK to start your tutorial. thanks
RDAOU
@Anonymous
Open a Section view or Elevation view >>> Go to Architecture Tab >>> on the Panel go to Datum >>> select level >>> Draw/Pick lines ... (Click Gif below to watch)
