Problem adding Regular door in Curtain Timber Wall
kegarc2002
kegarc2002
Can you guys help me.
I have to add a door in a Bearing Timber Curtain Wall. I modeled the opening to hold it but....
I'm doing something wrong, but no idea what.
I am also thinking I chose the wrong approach (again). Hopefully I will learn in the process.😓
Any help is appreciated.
Thanks in advance.
RDAOU
@kegarc2002
If you want to use a regular door, then you need to:
  1. Select the panel that should host the door.
  2. Select and unpin it.
  3. From the type drop-down menu, switch it to a basic wall (pre-create a generic wall with a single layer and the desired thickness).
  4. Once it's swapped to a basic wall, start the Door tool and place the door on the basic wall panel.
See GIF below
Personally, I prefer to model a Curtain Wall Door to avoid IFC classification re-mapping and hierarchy grouping later....
kegarc2002
Thank you for the help and the fast response.
I really appreciate it.
Thank you.
kegarc2002
I did what you told me to. It does work perfectly.
Thanks again. I appreciate it.
