Revit and perspective
silvia_llorenslopez
Message 1 of 10
silvia_llorenslopez
Hi, developer team!
Did you notice that perspective is awful?
It´s completely ¿inside-out? upside-down? Backside_front? ok.... you understood
I hope you can fix it
Silvia
Replies (9)
Message 2 of 10
Simon_Weel
The Properties panel isn't completely visible, but it look like the view is Ortho. Switch to perspective?
Message 3 of 10
arq_42
It's definitely in ortho since the paper airplane doesn't appear in that bar.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
Message 4 of 10
RDAOU
@silvia_llorenslopez wrote:
Hi, developer team!
Silvia
It is not broken. It might not have as many options as other software has in terms of vanishing points variations but its not bad...Further enhancements are expected in the future versions. To use perspective, either change the view mode the was Simon mentioned or you can also right click the 3D cube and switch to view mode to perspective.
See below Ortho vs Perspective
The scale menu will be locked and the view will be labeled "Perspective"
Message 5 of 10
silvia_llorenslopez
Hi!
Maybe is in ortho Mode, but the visual effect is that perspective is not ok. That's not exactly an ortho view, it's distorted,
Message 6 of 10
Simon_Weel
Ok, so what should it look like? I don't see anything out of the ordinary....
Message 7 of 10
silvia_llorenslopez
It's distorted. Ortho Mode should have parallel lines.
Instead, it looks like a perspective but it's distorted anyway
Message 8 of 10
mhiserZFHXS
You know that none of those buildings are perpendicular to each other right? Its not distortion.
Message 9 of 10
silvia_llorenslopez
I can´t find the file now, sorry
Message 10 of 10
arq_42
You don't need that file to check it at all.
Just create a new project and build a square with walls. You'll see they're parallel in 3D. 🤷‍
