Printing to PDF in revit
buckley-j6
Message 1 of 8
buckley-j6
HI everyone i am having a lot of trouble printing my plans to a high quality as it will not allow me to use vester printing and i am getting this notification every timeissue revit.JPG i try to print my sheet can anyone help me with this i have shadows turned off and no sun path on either
Replies (7)
Message 2 of 8
cbcarch
Vector or Raster is for Hidden Line. If you have depth cueing, shadows, shaded views, etc. Revit will default to Raster
as these effects are "pixel" generated vs "vector" (lines).
Try using Presentation Quality setting.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 8
buckley-j6
i have tried to print in presentation view with no improvement these are my settings is there anything i should change to maybe help with this issue printing.JPGvg revit.JPG
Message 4 of 8
cbcarch
  • Looks like you are using the Microsoft PDF Printer driver.
  • What version of Revit are you using?
(Revit 2022 will now print to PDF internally without use of 3rd party PDF print drivers.)
  • Did you try Raster instead of Vector?
  • When you say you are not getting good results, can you provide more detail and attach an image which shows exactly what is not printing how you need it to?
  • Try using Bluebeam or another professional graphics grade print driver.
Cliff B. Collins
Message 5 of 8
buckley-j6
i am a student and new to this all use to using autoCAD. i am using revit 2021. are any of them pdf drivers free or do you know what one would be the best option for me instead of microsoft
Message 6 of 8
cbcarch
A quick Google search found this:
https://www.bing.com/search?q=free+PDF+print+drivers+for+Windows+10&form=EDGSPH&refig=68b3c6261a774f...
Also please note that a recent Windows Update has caused printing PDF problems.
The solution is to roll back to a previous Windows Update.
Cliff B. Collins
Message 7 of 8
cbcarch
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Cliff B. Collins
Message 8 of 8
syman2000
Do you have one view set to shade, consistent or realistic? I notice if one view has it, it will turn the rest of the view to raster print.
