HI everyone i am having a lot of trouble printing my plans to a high quality as it will not allow me to use vester printing and i am getting this notification every time i try to print my sheet can anyone help me with this i have shadows turned off and no sun path on either
Solved by syman2000. Go to Solution.
Vector or Raster is for Hidden Line. If you have depth cueing, shadows, shaded views, etc. Revit will default to Raster
as these effects are "pixel" generated vs "vector" (lines).
Try using Presentation Quality setting.
i have tried to print in presentation view with no improvement these are my settings is there anything i should change to maybe help with this
(Revit 2022 will now print to PDF internally without use of 3rd party PDF print drivers.)
i am a student and new to this all use to using autoCAD. i am using revit 2021. are any of them pdf drivers free or do you know what one would be the best option for me instead of microsoft
A quick Google search found this:
Also please note that a recent Windows Update has caused printing PDF problems.
The solution is to roll back to a previous Windows Update.
Do you have one view set to shade, consistent or realistic? I notice if one view has it, it will turn the rest of the view to raster print.
