PRINTING ISSUES
PRINTING ISSUES
ngurearchitect
Message 1 of 12
PRINTING ISSUES
ngurearchitect
I have two issues here with regards to printing :
1.  Revit has completely refused to print for some reason.
2. My Microsoft to PDF print set up option does not provide enough choice of papers.
Any suggestions?
Replies (11)
Message 2 of 12
ennujozlagam
you can try another printer driver like BULLZIP and see if you can print. thanks
Message 3 of 12
ngurearchitect
 It still hasn't worked ..no matter which pdf printer I use once I click print its completely unresponsive and I don't know why ...
Message 4 of 12
ngurearchitect
In fact the only option that works is batch file printing
Message 5 of 12
ennujozlagam
have you try to install latest updates from autodesk, sometimes if fixes issue. another way is to check your OS windows by referring to this LINK or worse scenario is either to repair or  clean uninstall and reinstall your revit program and see if helps. thanks
Message 6 of 12
ngurearchitect
yes I have the latest revit update 2020.2
Message 7 of 12
ennujozlagam
you can refer to this article and see if helps. thanks
Message 8 of 12
ngurearchitect
my problem doesn't seem to be listed.
Message 9 of 12
ennujozlagam
if you choose microsoft print to pdf these are the only available papers sizes you can choose, my recommendation is to use another printer driver available in the internet for free. are you seeing this when you print to pdf? thanks
Message 10 of 12
ngurearchitect
I am not using Microsoft print to PDF ...in fact my printer dialogue does not allow me to print after making all other changes once I click okay nothing happens.
Message 11 of 12
ennujozlagam
what pdf printer driver you are using. thanks
Message 12 of 12
ennujozlagam
the only way is do a clean uninstall  and reinstall again your revit program, it could be some files are corrupted. thanks
