Printing in dark canvas theme
kevboe0710
Message 1 of 13
kevboe0710
Hello all,
In reference to the dark canvas theme, does anyone know how to print to PDF in this dark theme?  It appears the print function resets the theme to Light, even if you are actively viewing your work in dark.  Any suggestions?  Thanks!
Replies (12)
Message 2 of 13
You want to print it? The canvas color?  What's your budget on black ink? Unlimited? 😉
...or maybe you are after a blueprint effect?
How To Create a Blueprint Effect in Adobe Photoshop - YouTube
Message 3 of 13
kevboe0710
Haha. I only want to print to pdf so I can share it with others in the dark theme.
Message 4 of 13
It's the canvas mode though. If you want others to see your Views in Dark Mode, then send them your RVT and tell them to activate Dark Mode when viewing.
Message 5 of 13
kevboe0710
It’s for people without access to Revit, which is most people.
Message 6 of 13
What about the free Revit Viewer?
Download Autodesk Viewers | Free Online Viewers | Autodesk Official
Message 7 of 13
L.Maas
What about screenshots or export to image and then convert those to pdf?
Louis
Please mention Revit version, especially when uploading Revit files.
Message 8 of 13
kevboe0710
Screenshots and export to image works, in that it keeps the dark theme (blueprint theme).  But, both are blurry and mostly unreadable.  I will work on adjusting image export parameters to see if it can be sharpened up.
Message 9 of 13
kevboe0710
Exporting to image worked and I was able to adjust the export image settings to create a sharp image!  Below are the settings that I used.  Thanks!
Message 10 of 13
mhiserZFHXS
I thought you were crazy as well until you clarified that this was for PDFs. Might not be a bad idea to post to the idea board.
Message 11 of 13
kevboe0710
Where's the idea board?
Message 12 of 13
L.Maas
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Louis
Message 13 of 13
vanessa_coronado
Community Visitor
Community Visitor
I was trying to do the same thing. I came across messing with the "graphic display settings" at the bottom. For the shaded setting, you can change the background color of your view to black or whatever you prefer and then save as pdf and it will translate.
