Printing hatch pattern printing problems!
Message 1 of 14
I have 2 different views at differing scales 1:50 & 1:20 respectively of the same room (an accessible WC) on a sheet. Both display floor hatching when viewing the sheet but when I attempt to print them the 1:20 view does not print the hatch pattern.
I have created a view template of the 1:20 view and applied it to the 1:50 view, but this does not change things. I want to print the hatch pattern as part of the 1:20 view.
Can someone please help me before I rip out my eyes! 🙂
Raoul
Replies (13)
Message 2 of 14
please don't rip out your eyes..
i'm sorry i don't have your answer off the the top of my head-
but i'm sure someone will.. relax- get a grip- do something else
while you are waiting for an answer..
Message 3 of 14
Thanks, I'll take a couple of deep breaths. Just overreacting a little.....need my eyes, might just saw off my left arm. 🙂
Message 4 of 14
Jason_S
I am having the same problem. I can't figure out what the heck is going wrong. Shows fine on the sheet print it and it doesn't show. Happens in Revit 2009 and 2010.
I hope someone can shine some light on problem.
Message 5 of 14
rosskirby
You might want to try changing the print settings from vector to raster (under "Setup" in the print dialog box). If it's already set to raster, try changing it to vector.
Good luck.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 6 of 14
Thanks rosskirby, it worked (and I didn't even need to saw off my left arm)!
Really appreciate that.
Cheers,
Raoul
P.S. Can someone tell me what the little dot on the left is for in the discussion group? i.e. Why is it orange or half orange or not orange? Edited by: raoultittel on Feb 8, 2010 3:11 PM
Message 7 of 14
sham.summan
I had the same problem,  i change the lineweight in the hatch property from 13 to 1 and it worked.
Message 8 of 14
What "hatch property" did you change and where is that located? We are having this problem now, and of course its on a deadline....
Message 9 of 14
Good luck.
give me black and grey to my hatch
Message 10 of 14
BIMTarun
  • Change the line spacing to make the fill pattern less dense:
    • Manage>Additional Settings> Fill patterns
    • Select the fill pattern in use, and select 'Edit'
    • Change line spacing 1 and 2 to be larger
Message 11 of 14
DEP_ABC
The issue comes not from vector or raster and either of line weights.
From my experience, if you use parts, you will have that issue if you use both in the view, so:
In View Template or Properties (if you don't use template), <Part Visibility> change to show original.
It should solve the problem.
Good Luck!
Message 12 of 14
lionzay_123
Community Visitor
Community Visitor
It worked for me. thank you very muchhhhhh ❤️
Message 13 of 14
lionzay_123
Community Visitor
Community Visitor
It worked for me. thank you very muchhhhhh :red_heart:
Message 14 of 14
franckyleonelndam
Community Visitor
Community Visitor
Bonjour Monsieur vous avez bien compris le problème et j'en fais face j'aimerais bien que vous soyez explicite dans la résolution du problème
