Print Setup not working
AdamHamilton
Message 1 of 27
AdamHamilton
I am able to open Print dialogue but the Setup button does nothing. Doesn't matter which Printer i choose. the same printers are able to be printed from other applications. It is not file specific.
Accepted solutions (3)
Replies (26)
Message 21 of 27
gmarotis
Thanks for answering!
My problem is not with pdf printer, this works fine. My problem is with an HP printer (OJ 7740), I just replied in this thread because the problem seems really similar. And also what you say is true: I have to use another printer as default so as to use the print command because all other devices work fine.
What do you mean with "use p"?
Regards
Message 22 of 27
Sorry, Not 'use p' p to bring up the print dialog box.
Message 23 of 27
cadvis3d
changing windows default printer and turning off letting windows choose the default printer worked for me - stupid windows 10 strikes again.....this is the reason why i keep a machine with windows 7 just in case.....i still have the problem where by print spooler stops working and i can't print to my plotter, so have to use a windows 7 machine to get round the problem.....bring back windows 7!!! many thanks for posting - helped a lot!
Message 24 of 27
eaststar1
Observer
Observer
Thank you. That worked.
Message 25 of 27
cameron.mackenzie
If anyone is still having this issue in Revit 2017. We have just been on a call with a client and installing the 2017.2.5 Hotfix rectified this, this should be available in the Desktop App.
Message 26 of 27
mbuotidemakpan590
Community Visitor
Community Visitor
Similar issue while using using Revit 2017 currently
Message 27 of 27
RobDraw
The "me too" movement is getting out of hand.
Rob
