Print bug
Print bug
PCA_amagalhaes
Print bug
PCA_amagalhaes
Hi everyone,
I'm trying to print some PDF from REVIT and the Arial font is printing like this ?
Can you help me finding what is causing this bug ?
Regards
w/ @apointeau
RSomppi
Which is Arial, all?
What version of Revit?
What does it look like on the screen before printing?
Set the screen resolution to 1920x1080 and windows display scaling to 100%, restart and reprint, see if it helps.
syman2000
It could be windows update cause the PDF to distort. You may want to check the link below.
PDFs printed from Revit have distorted text, incorrect fonts, missing images or other problems after...
PCA_amagalhaes
Thank you for your answers.
@syman2000 I couldn't follow the troubleshoot (I couldn't install the update, even when I downloaded the correct .msu from Windows Catalog). I have instead updated my Windows version to 21H2 : even though I still got the print bug.
@ToanDN Your solution helped, but does it mean that I'm stuck in the 1920x1080 resolution ?
Regards
syman2000
Check this forum and see if the patch help with the print
https://www.revitforum.org/forum/revit-architecture-forum-rac/architecture-and-general-revit-questio...
