Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Prevent drag edit in family
cbt990
Message 1 of 12
cbt990
I made a family that is supposed to be only 18" or 20" square. When I create the size as an instance parameter, I can toggle between the two but also drag it to any other size. When I change the size to a type parameter, the family no longer changes size when I change the type. I'm kind of confused about how to get the intended functionality.
Revit is amazing
Replies (11)
Message 2 of 12
Seems fine here.
Message 3 of 12
Did you edit the type in the project and change the parameter under type properties?
Message 4 of 12
cbt990
I changed the type in the type selector:
and nothing happens.
When I change the parameter value, then it changes:
Isn't there a way to build a title block family with only selectable sizes as different types?
Revit is amazing
Message 5 of 12
You need to change the Size parameter value, not just the Type name.
18" is 1'-6" not 1'-8".
Message 6 of 12
cbt990
It's because the value isn't changing when I change the type.
Revit is amazing
Message 7 of 12
cbt990
So the type name is essentially unnecessary?
Revit is amazing
Message 8 of 12
The type name is good to be descriptive and should match the Size parameter otherwise it is backfiring.
Message 9 of 12
cbt990
They don't seem to change correspondingly, is the issue. I can update the parameter to the wrong value in the wrong type. How do I prevent that?
Revit is amazing
Message 10 of 12
You need to make two types just like you're doing.  When you toggle the Type, you need to accept it.  In other words, and "swap" isn't made instantaneously. You need to follow through.
...Have you loaded and placed this Family in a Project yet?  Once you do, you pick the Type via the Type Selector just like you do with any Family.  The Type Properties are irrelevant to this operation.
Message 11 of 12
How do you prevent entering the wrong value for the parameter?  Bruh, you just have to pay attention when doing it.
Message 12 of 12
mhiserZFHXS
@cbt990You really need to look into some basics of family creation, specifically how instance and type parameters work. There are plenty of resources on YouTube that should straighten out your issues pretty quickly. I commend you for taking the dive.
