Precise Grading Plans - How do I generate a precise grading plan?
11:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working in Revit 2017 and Civil 3D 2017. I need to be able to prepare a precise subgrade plan in either Civil 3D or Revit reflecting the top of compacted subgrade (bottom of spread and continous footings, as well as bottom of base material (Type II Compacted Base usually a part of the slab-on-grade assembly). This needs to be able to imported into Civil 3D as a surface to generate a volume surface for export/import calculations and for the surveyor to perform construction staking.
What is the best way to get there utilizing one or both of the two software types?
Kindest Regards-
Greg Waters
