install revit 2017
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mishkt
912 Aufrufe, 2 Antworten
install revit 2017
I have a problem with installation of revit 2017.
When I use "install now" and running, it stop download on 181 mb (screen shot 1)
When I use "browser download", it show me error (screen shot 2)
"Run as administrator" doesn't help.
May be someone had same problem and can help
Thank you in advance
2 ANTWORTEN 2
Nachricht 2 von 3
jeffrey.sin
als Antwort auf: mishkt
Hi @mishkt,
The browser download for Revit 2017 consists of 2 parts, and it seems that you only have one part of the installer downloaded thus you are getting that error. Kindly try downloading both parts of the installer from the Virtual Agent once again, and this time ensure that you have both Part 1 and Part 2 downloaded and saved onto the same folder before running the part 1 .exe file. You may refer to this article for more information on Downloading Autodesk Software Using the Virtual Agent.
Let us know how it goes. Thank you.
Jeffrey Sin
Autodesk Customer Support
Nachricht 3 von 3
JvanReij
Dear Alena,
Thank you for the post.
This is a known issue, wich most likely occurs because of your pop-up blocker. If you like I can explain it to you, but in the link below Autodesk already made a nice overview of this issue. Even with pictures to follow.
Link solution pop-up blocker
Would like to hear if it is solved, if not feel free to contact me!
Best regards,
Josha van Reij
AEC Consultant
Cadac Group
Best regards,
Josha van Reij
Arcadis NV
BIM manager
