Precast problem solution.
edgarsceplis09
Message 1 of 23
edgarsceplis09
Firstly wanted to try split my floor with using precast function "split", to make hollowcore concrete floor. And it says: Revit structural precast content is missing. Please select the content folder appropriate for the current language. And this problem is on everyting in precast tab.s I tried to also download other libraries and check it for acceptable content. Maybe someone can help to solve this problem?
Replies (22)
Message 3 of 23
edgarsceplis09
Yep, i found it, but i have 2024 revit, so this method is invalid for me.
Message 4 of 23
Do you have a C:\ProgramData\Autodesk\RVT 2024\Libraries\English\US\Structural Precast Folder?
Message 5 of 23
jay_colc
in 2024 it is now located under the English > US file location which was not the case previously
Jay Colcombe
Autodesk Certified Instructor
Message 6 of 23
@edgarsceplis09: this is what you should see - a link that you can press to automatically load content:
Message 7 of 23
Have you run configuration?
Message 8 of 23
edgarsceplis09
My revit after update give me link to download content. So thanks for help.
Message 9 of 23
GCFEL
I have no 'Structural Precast', how do l get it for Revit 2025?
Message 10 of 23
GCFEL
How did you get the Precast content for Revit 2025?
Message 11 of 23
jay_colc
It pre-installed but in the U.S. Metric Library location!
Jay Colcombe
Message 12 of 23
jay_colc
If you mean Precast families you need to install the Content from your Autodesk Account or from the Insert Tab > Load from Library > Load Family and search for Precast Content
Jay Colcombe
Message 13 of 23
GCFEL
I do not have 'pre-installed U.S'.
Message 14 of 23
jay_colc
are you using Revit LT?
have a look here this will walk you through it
https://forums.autodesk.com/t5/revit-structure-forum/precast-content-is-missing/td-p/12703384
Jay Colcombe
Message 15 of 23
GCFEL
Rull trial Revit 2025, soon to go to subscription.
Message 16 of 23
GCFEL
I downloaded the UK collection and installed today, however, no precast content was installed.
Message 17 of 23
jay_colc
Are you trying to use the Precast Tab?
or
Use a Precast Column or Beam?
it’s really not clear!
Jay Colcombe
Message 18 of 23
GCFEL
I am trying to use the precast tab, however, when selecting a button it asks to browse for content, which l do not have even after installing library content.
Message 19 of 23
GCFEL
Precast tab. Asks to browse to locate content, which l do not have, even after library installation.
Message 20 of 23
jay_colc
Nothing here?
Jay Colcombe
