Firstly wanted to try split my floor with using precast function "split", to make hollowcore concrete floor. And it says: Revit structural precast content is missing. Please select the content folder appropriate for the current language. And this problem is on everyting in precast tab.s I tried to also download other libraries and check it for acceptable content. Maybe someone can help to solve this problem?
Solved by barthbradley. Go to Solution.
Yep, i found it, but i have 2024 revit, so this method is invalid for me.
Do you have a C:\ProgramData\Autodesk\RVT 2024\Libraries\English\US\Structural Precast Folder?
in 2024 it is now located under the English > US file location which was not the case previously
@edgarsceplis09: this is what you should see - a link that you can press to automatically load content:
My revit after update give me link to download content. So thanks for help.
