Post base offset
Post base offset
chriskD6WP2
Message 1 of 18
Post base offset
chriskD6WP2
Newbie here...
I'm having difficulty placing the bottom (or base) of my guard rail posts where they need to be in my models. Currently, I need to be able to show the posts mounted to the side of some platforms. As it stands, I am unable to model it this way (see screen shot).
Whenever I specify a base offset, you can see the post just moves down in elevation. Help? Ha!
Replies (17)
Message 2 of 18
Probably be easier to show you, than to tell you. Want to post a simple RVT file with the railing type placed in it? If not, post screenshots of your Rail and Baluster properties so we can reference them.
Message 3 of 18
Message 4 of 18
chriskD6WP2
That doesn't do anything for me.
I'm waiting on a screen cast to process.
https://knowledge.autodesk.com/community/screencast/9d072039-dc98-46b4-acaa-e3f6ba97eaab
Message 5 of 18
How about Start Post and End Post base offset?
Message 6 of 18
chriskD6WP2
This is what I get by changing those perimeters.
Message 7 of 18
Maybe it's time to share your railing model.
Message 8 of 18
chriskD6WP2
No problem but where would it be saved? I'm not familiar with that part of Revit, yet. LOL!
Message 9 of 18
Have you thought about just using a base offset on placement?
Message 10 of 18
Just copy paste a railing to a new file, save, and attach.
Message 11 of 18
chriskD6WP2
Didn't know you could do that! Thanks!
Here ya go.
Message 12 of 18
chriskD6WP2
I have to leave my office. I'll check back in the morning.
Thanks guys!
Message 13 of 18
Base offset? No? (Instance Properties)
Message 14 of 18
The post family you used was modeled incorrectly.  It does not flex when the height changes.  I replaced it with the stock Round baluster of the same size and the railing now works properly.
Message 15 of 18
Better than offsetting. Top rail remains to code.
Message 16 of 18
chriskD6WP2
Thank you so much!
I find it interesting how the family I used to create the rail didn't flex I it should. Again, being a newbie, I just thought if I started with what came with the software package I would be fine. Lesson learned. Thanks again!
Message 17 of 18
Edit the Baluster - Round or Baluster - Square family and see how they are built.   There are voids constrained to the two sloped reference planes to chop the overly tall baluster to the correct height when placed in railing.
Message 18 of 18
chriskD6WP2
ToanDN,
Do you know why the middle post or baluster will not extend down like the other two? This is the rail model you mixed for me earlier this month.
